1 - 2 of 2 Posts
Yesterday i go to crank up my car, and when i turned the key into the on position, it sounded like a small man with a hammer was trapped under my hoods. Then the engine turned over about 8 times before it finally caught. Once running at idle, i noticed that the throttle was basically non-existing. i tried replacing relays, reseting the computer, and pulling out my hair. this morning i tried again after leaving the battery unhooked all night, and now it wont even crank. any suggestions?
Stripped timing gear? If the chain jumps on the gear it could throw off the crank position sensor, and it would NOT run right.
1 - 2 of 2 Posts
