1 - 20 of 31 Posts
That is the correct size slick but you can run a size wider. I have 26x11.5x15 hoosier qtps mounted on weld prostar 15x8 rims and they fit just fine, i cant wait to try them at the track. The tire you listed also will fit best with a 15x8 wheel and the backspacing you want is 4.5
most common is a 26x10.5x15 on a 15x8 rim with 4.5 bs. the only reason im running slightly wider is becase thats what the guy had when i bought them from him. JayC is running the same tire setup i have on 15x8 rims with no problems
!FACEPLATED!
link no worky mellow. but with the wheels you get 15x8= 5.5 b.s and 15x10= 6.5 b.s.
!FACEPLATED!
bolt pattern is to big. our cars are 5x 4.5 and i think that bs is a little shallow
!FACEPLATED!
i just ordered some 15x4s with a 4.5 bs. not sure if i will need a small spacer or not yet
1 - 20 of 31 Posts
