1 - 6 of 6 Posts
if i built a 347 from dss with 10.9:1 compression would it be alright if i sprayed 100 shot only at the trak......it's gunna have 4:10 gears.....
yes.....nitrous is not like boost.....you can run high compression and nitrous together
so then it would be alright if i put a 100 shot on it no problem....
yes......just make sure everything is right with tuning
i hope your buying a good ignition.......
also is your car a standard or automatic? Just curious because if it's a standard 4.10 gears might be too low, 3.73's would be the way to go....
1 - 6 of 6 Posts
