I need help finding a 12 volt ignition source under the dash to tie my pillar gauges into. Anyone know off hand or have wiring schematic for under the dash?
I tapped my 12V switched into my KB's intercooler morot circuit. There's a lot of switched sources in that under-hood fuse box. Get a test light and you'll find one pretty easy.
I wouldn't tap any wires without first checking it with a volt meter... Its just a good practice... The main switched 12volt from the key switch is yellow/white (yellow w/ white stripe)...
Major rep...i was out there 4 hours todau under the hood in that fuse box looking for 12 volt ignition....10 minutes after you posted this im online!!! thanks bro!!!
no problem, anytime man. if you need any other help with your gauges let me know. get some pictures up too, ill have some up as soon as i get my car out of the body shop
