1 - 5 of 5 Posts
Has anyone used it on a 05-09 car? If so whats the ride like, did everything install perfectly, and was ride height un effected?
What is all included in that package? Bigger brakes? Sway bars? Control arms? Most of the stuff fits. You need to use the struts and springs together, they are not interchangeable with our year. Upper control arm mount needs different bolts. might be a couple other small differences. i believe the ABS was re-calibrated in those cars to utilize the capacity of the tires and brakes that came with that package.
At the Apex pulling 1.28g
Ride height will definitely be effected. Your 05-09 cars will sit taller because the 13-14's are heavier. The front will especially sit higher because the weight distribution is also jacked up. The 05-09's are in the 53%-54% range, the 11+ cars are all in the 56-57% range for weight bias.
As for how it would ride, meh. Crap dampers with stiffer (but not stiff) springs = healthy dose of meh.
Really just curious if the struts/shocks will fit.
Sure would, with 2011+ strut mounts.
Ok gonna stay away from it then thanks brotha
1 - 5 of 5 Posts
