1 - 6 of 6 Posts
im also stuck with the thermostat :mad:, i need a 160* and we dont have hypertech in lebanon, any GM 160* thermostat that can match it?
Thank you
I don't think so, our thermostats are way different than a gm. Your not going to gain anything from the trick anyway. But you could mabey round up a 180 from summit or late model restoration ect
No gains can be had with changing the thermostat and no you can't use any GM thermostat. What do you mean you don't have Hypertech in Lebanon?
I think he means he has the hypertech programmer, bout the only thing i can thing of
I meant Hypertech the brand. Hypertech Power Stat 160 degree thermostat Mustang GT (05-09)
Im trying to lower the engine heat i posted before that it is hesitating on low rpm and perfomance dropping down after sitting in a traffic of driving about 30 minutes. Scanner showed nothing and all cooling system are normal.
1 - 6 of 6 Posts
