1 - 20 of 129 Posts
I took this in trade toward some labor on a 68 Shelby we painted. It had a 302 with a C4. I started out wanting to build it with the Trans Am Racing look. I had to replace the floor pans, torque boxes, trunk floors and a few other patches. I flared the fenders and quarters a little and bonded in the Shelby end caps. I went with the Rod & Custom Mustang II front suspension and have decided to run a 4.6 engine and trans out of my Dad's wrecked 1995 T-bird. This will be a long term project since it is my car and I have a lot of customer cars that come first. It will take a little time to get you updated.
Here are a couple of pictures showing how I flared the fenders and quarters. I cut the fenders leaving them attached at the bottom and than added about 1 1/2 to the flare.
The rears were a lot harder because you have the inner rear wheel well to flare also.
Rod & Custom Motorsports front and rear suspension.
The engine compartment is ready for paint.
Mock up of rear suspension
Bottom of body epoxy primed and than sprayed with SPI bedliner
I thought I would give you an update with the Rod & Custom coil over front suspension installed.
Discussion Starter #2
Rod & Custom coil over rear suspension in my Coupe. The rear center section is not installed yet. This is the first time I have installed everything on the car with a 9" rear end out of a 1963 Galaxie.
I changed my mind on the taillights. I was going to put a deluxe ribbed taillight panel in and I had cut out the original taillights. Now I have decided to french them in instead. I had put a reproduction taillight panel in our Eleanor project and cut out the original taillight mounting area.
The reproduction taillight mounting area was about 1/4" to big so Brian cut it down and welded studs on it.
Brian welded it back in and now has to grind the welds.
Lost in the 60's
Any chance you could post some details on frenching the tail lights? I've been looking for a kit to do this and can't find one, so I guess I'll have to roll my own.
Use an old gasket and taillight and bolt on 1/4" studs than weld the studs to your taillight panel. Grind the welds and than use a little filler.
The only reason we used a piece from another taillight panel is because I had ruined mine and had to replace that section
After the welds were ground
The cowl vents were filled in along with the heater holes in the firewall
I removed the drip rails
Bodywork on the flares
Black SPI epoxy primer and than sprayed 2 costs of gray Slick Sand polyester primer
DEC '12 ROTM CO-Winner
:eek: I love those frenched tail lights, I would be afraid to try it on my own and a shop would probably charge alot for it. Definitly on my list of what I want now. :D looks amazing.
Discussion Starter #19
^This, and maybe a photo or two of that Sierra XR4i. Kinda curious whats going on with that as well. I love those flared fenders though :drool that is one more thing you added on my list of wants. Along with those frenched tail lights.
We have stopped working on the Cosworth powered Merkur
Discussion Starter #20
I did not like all the gaps on the fiberglass rear bumper so I narrowed it and extended the ends to meet the end caps.
The deck lid sticks out to far on the bottom
I added fiberglass to the back and sanded the front to match the end caps
1 - 20 of 129 Posts
