61 - 69 of 69 Posts
Discussion Starter #62
I need to get you caught up.
Body was seam sealed
Engine compartment sanded
Epoxy primed
The body was block sanded and the engine compartment, interior and undercarriage taped
The body was sprayed with a sealer coat of SPI red oxide epoxy and today spayed two coats of SPI Turbo primer
Discussion Starter #65
The body was taken off the cart and mounted on a rotisserie so we could work on the undercarriage
Brian had to fill in the screw holes he drilled to fit and weld the seat risers.
Welds ground
Undercarriage sanded
The owner decided he wanted the undercarriage black
Discussion Starter #68
Seam sealed and ready for the last two coats of SPI black epoxy on the undercarriage and engine compartment
Discussion Starter #69
The engine compartment and undercarriage was sprayed the final finish coats of SPI black epoxy.
Back of the deck lid and hood sprayed Acapulco Blue
61 - 69 of 69 Posts
