1 - 8 of 8 Posts
A few questions about the 1994 5.0 motors. First I am assuming that both the GT and Cobra motors have aluminum heads correct or no? Also is there a difference in the heads between the cobra and the GT in 1994? Or is there any big differences at all i should know about when looking for a nice project car. Also my plan is to build a 351 and do a block swap. The transmission and heads and all that **** should fit right?
If your going to do a 351 swap, why does the differences between the GT and Cobra matter? Neither the GT or Cobra have aluminum heads. The GT shares the same heads the 87-93 fox bodies use, which are E7s. The Cobra uses iron GT40s. The cams are slighty different between the two, but both are hydraulic rollers. The intake manifolds are also slighty different. The Cobra got a 65mm throttle body, as where the GT got a 60mm, and the MAFs are also different. There are other small differences, but these are the ones that stand out the most.
1 - 8 of 8 Posts
