1 - 11 of 11 Posts
hello i am new on here and i am trying to get my car started after replacing the fuel pump. fuel filter. and buying a new battery. anyone have any insight on why it wont start?
Wha...?
Inertia switch most likely. Look in the trunk on the drivers side and there will be a panel to remove and reset the switch.
thanks i have tried and nothing i also checked the spark and one line is not sparking. but that should not stop my car from starting. what else is there that i can check or do i am stuck.
Discussion Starter #9
it wants to start but just wont
i know i am getting fuel to block and i am getting spark but other than that i dont know what is going on
Wha...?
If the fuel is making it to the rail, at what pressure is it doing so? If the pressure at the rail is good, and you are getting spark then the only other thing it could be is the injectors. Check to see if they are operational, if they are in fact opening and closing, then it will be be clogged.
1 - 11 of 11 Posts
