1 - 3 of 3 Posts
Hey all,
I have another question for you all. I replaced my keyless entry's batteries today and I need to re-program it to my car.. Any help with re-programming it???
P.S. I disconnected my Negative cable on my battery too.
Please/Thank you,
Ryan
u shouldnt need to, but if you take your rear driver side trunk panel out, there is a control box pretty much right over the rear driver side wheel. there should be two metal nobs there. connect the battery, if you take a metal object and connect the two nobs the locks should rotate (lock-unlock) or just lock once to where it locks, once that happens push and hold the lock button on the remote, it should be set... if it is the second way... the locks should unlock.
hope that helps
1 - 3 of 3 Posts
