My check engine light was on recently. I fixed the issue, unplugged the battery for 20 min, plugged it back in, scanned and had zero codes
The other day I turned the car on and after I motioned fwd with the key two clicls some of the dash components light up. The check engine light was one of them. However, when I turn the car on it does not stay lit.
Is this normal? Not sure I took note before hand. Also when you unplugged your battery for 20 minutes (and do not fix your issue) does the check engine light go away? I want to make damn sure this issue is fixed.
Thanks!
Thanks!
