they make a tool for that cheap ass. :lol j/k
LOL why bother paying for it??? You can rent it from advanced for $40 then get the $40 back when you return it.
Changing out your springs is rather simple...i finally finished mine up tonight. The only part that can be a PITA is the top nut for the front struts...i didnt have the proper tools to do the job, so keeping the strut rod in place while loosening the nut was a fun job. I replaced the sway bars, shocks and struts, and springs when i did this so not everything may apply...
To do the Front...
jack car up, put jack stands on fron frame connections (they are just behind the motor real hard to miss)
disconnect caliper (two bolts, think 13mm) if the spacer starts to spin you will need to hold it in place with a pair of pliers.
disconnect abs sensor (or carefully remove from hold downs, and keep an eye on when raisng lower...i had to do this because the tokico struts are a bit wider than stock, so it was a PITA getting the sensor back in)
take jack and jack up the a-arm of the side you are working on (just below the spring works perfect) Just jack it up enough to put pressure on it, but not enough to raise the car.
Disconnect sway bar (think 15mm but not sure)
Remove bolt from top of strut (22mm) ...to do this you are going to need something to stop the strut from spinning, i used a chizel (but definatly not a prefered method)...if you have a large screw driver that should do the job just fine.
Slowly lower jack...as the jack is coming down, guide the strut down and compress it as it is coming down.
Remove the jack
Now the spring is ready to come out...use a pry bar or something (i used my 22mm wrench) pry at the base of the spring and with some wiggling it will come out.
Follow in reverse for installing the springs (only difference is that you will have to jack up the a-arm to bolt up the strut) It might also be easier to leave the sway bar disconnected until both sides are done. Oh and i have to emphasize one thing about the front spring
MAKE SURE THE FRONT SPRINGS ARE ALL THE WAY IN THE POCKET...you will know what im talking about once you look at it.
Rear spings are real easy....i did the front one side at a time (definatly recommend that) on the rear i did it all at once, made it very easy.
Jack up car and put stands on rear frame.
put jack under side you are working on and jack up to put some tension on it.
disconnect quad shock (18mm i think) (its the vertical shock)
disconnect sway bar (18mm) (not sure if you need to do this, i did it because i was replacing it)
Remove side inner panels to get to shocks
remove top bolt (15mm) from shock you are working on (has jack under it) i used a pair of pliers to hold the center rod from spinning
slowly lower jack and guide shock down and compress shock as its coming down.
Do the same for the other side
To remove the spring jack up opposite side of spring you are working on...spring will get loose enough to push out by hand.
Install in opposite order.
