1 - 3 of 3 Posts
1. Can you reuse valve cover gaskets?
2. If the timing chain is off one tooth do you lose power?
Thanks for the help.
As far as the valve cover gasket, yes you can reuse them long as they aren't damaged. and if the timing chain is off you want to get that fixed ASAP before you possibly cause damage.
1 - 3 of 3 Posts
