1 - 1 of 1 Posts
hi, Steve here in middle of Mo.my ford ,when first starting it will surges at idle,engine light is on and throws a 401 code,(excess air flow),I've replaced ever thing in the EGR system! and no luck,when its cold the car sometimes dies after idling for a few min's. you mentioned that replacing ,(or was it reprogramming)the computer may fix the problem in one of your replies to another member on this site,I was wondering if you had any work on your computer that may have cured the problem in question?or can the stock computer be recalibrated too, or beyond the normal realms to compensate ? or can I install another brain box (say a MDS, or Jacobs,or maybe a chip) inline in the same system?give a reply if you got the time or know someone that might2001 3.9 332:tomato:eek:
1 - 1 of 1 Posts
