1 - 3 of 3 Posts
MAF AD COUNTS and ENGINE SPEED
Are all over the place during trying to catalog tune. I've already ran through some writing to the body control module any input would be thankful.
Below is the build list:
Using sctx3
LIVELINK software
Vortech v2 3.33 pulley
Snow performance stage 2 meth kit
Hi tech stage 2 blower cams
Full bolt ons
Long tubes
Lightning 90mm MAF
60LBS FORD LIGHTING injectors
90mm TB
90mm Plenum
Professional industries intake manifold
4.10s
31 spline axles
Can you email me the datalog file? [email protected]
It looks like the maf is pegging, either the sensor is bad or grounding out on something, but its hard to tell with the quality of the picture.
King Trashmouth
Yeah that picture quality is pretty lousy.
Are you logging this on the handheld and reading it later, or are you logging it straight on the laptop? I've seen issues where if you log it on the handheld you get some bad MAF data. I would update all your software/firmware and log it again on a laptop with Livelink II.
1 - 3 of 3 Posts
