I anm getting ready to take apart an 85 GT. Going back together I plan to put some 01 Cobra brakes on it. I have the 01 SVT wheels to go on it and have got some 95 spindles for the swap. I am also putting a 95 rear disc 8.8 in it. With this said, My questions are; What lower front control arm should I use? I want the front tires to be as wide as the rear (the rear is 1.5" wider as I understand it) if possible. I probably will put a tubular k-member in it. #2- going with the cobra brakes will I need to change the MAster cylinder to a larger diameter piston master cylinder? If anyone has any helpful info , just let me know, Dman
