1 - 17 of 17 Posts
6 Cylinduh, Really Bruh?
I am making this thread more for personal tracking - but putting it up in case anyone has questions. While people have way bigger builds then I could ever dream, this car is very sentimental to me and I'll probably have it til I die (or the oil runs out).
Mods:
Engine:
Airaid CAI with Dryflow Filter
BBK Throttle Body
C&L Plenum
Accell COPS
Catch Can
SCT X4 tuned by SCT - 93 Octane Race Tune
Hood shocks to replace hood rod
Transmission:
Exedy Stage 2 Clutch
Exedy Light Weight Flywheel
FRPP Aluminum Driveshaft
MGW Short Throw Shifter
Royal Purple Sychromax Fluid
Adjustable firewall cable adjuster
New Ford Clutch Cable
New UPR clutch cable quadrant
New Clutch Fork
New FRPP TOB
New FRPP Pivot Fork
New FRPP Pilot Bearing
Rear End:
3.73 FRPP Gears
Moser 31 Spline Forged Rear Axels
FRPP Rear Girdle
FRPP 31 Spline Cobra 8.8 Rear Diff
Everything rebuilt with FRPP rebuild kit
Royal Purple 75W-140 Gear Oil
FRPP Rear Pinon
Suspension:
Steeda Sport Springs
MM Shorty snubber
BBK Gripper series rear Upper and Lower Control Arms
Maximum Motorsports FLSFC
MOOG outter tie rod ends
MOOG lower ball joints
MOOG strut bar connections
MOOG poly strut bar mounts
SVE caster/camber plates
Front Strut Tower Brace (SR Performance)
BMR upper and lower rear control arm braces
Koni STR.T shocks and struts
Rear strut tower brace (SR Performance)
Poly spring isos
BMR Battle Box Reinforcement Kit
Wheels:
Staggered 17" FR500's on Nitto 555 Tires
R1Concepts Geomet Drilled and Slotted Rotors
Cosmetic:
03/04 Cobra Front Bumper with Chin Spoiler
Shorty Antenna
Bullitt Fuel Tank Door
New Wiper Cowl
Tint
13-14 Rear Tail Lights (Raxiom) with sequential blinkers and relay to slow them down
Retrofit Headlights (Morimoto H1 Mini 7.0s with Morimoto bulbs, ballasts, wiring harness, and holders)
3" LED projectors retrofitted in Cobra Fog Light holes
Red MUSTANG logo in bumper
New convertible top
LED tinted third brake light
Exhaust:
BBK Ceramic Long Tube Headers
BBK O/R H Pipe with Magnaflow Metallic Core Cats welded in
Borla Stingers
New Motorcraft O2 sensors (primary)
Sound:
Pioneer 7" Touch Screen In-Dash
NVX 6.5" Components in the front (6.5 conversion in door for mid bass, tweeters in stock Mach 460 location)
NVX 6.5" Components in the rear
Rockford Fosgate Prime 400.4 Amp to run highs/mids
Optima Red Top Battery
Big 3 Upgrade
Entire car sound deadened - double on the doors and trunk
Alpine Type R 10" Subwoofer in Ported Box - Tuned to 34HZ
Rockford Fosgate 800W Amp to run sub
Interior:
New Lloyd GT floor mats
New Lloyd trunk mat
Billet door lock pins, and light switch
LED lighting
Beltronics MAX360 Radar Detector hard wired and Blend Mounted to the rear view mirror
Mustang Cue Ball Shift Knob
Chrome bezels on dash
Cipher Auto Black Cloth with Grey stitching racing seats and brackets with suede inserts
FR500 Steering Wheel from LMR
Do you have any pictures?
I’d love to see some.
Sounds like a great build!
What a coincidence! I have a 01 GT Vert as well! Metallic Silver here.
This was in projects. Sorry to muddy up clubhouse with this.
Yes need to supercharge lol. I'm budgeting it for my next step. Been saving up money and doing research on the best route. Leaning towards vortech and leaning towards new versus gambling on a used unit unless I find one locally or from a trusted source. Additionally I feel paint might be the more pressing issue. Now that my goal of getting it to where it is now is done I need to plan again. I'm OCD about this stuff.
I'll post pics when on my pc. I take a lot
missippi roolz
Projects is now Clubhouse as well
I wanna see some pics of your car also. That is a long list of things you have done to it, mine needs to look like that also, but I'll have to add new engine.
I have a 2001 GT 'Vert as well! The best part was trying to figure out which parts were pre-2001 and which parts were post-2001 when buying flywheels and clutches and whatnot. I mean, it hardly matters anymore since replacing both the engine and transmission, but it was still a righteous pain in the ass.
Seconding the motion for pictures. What color?
Discussion Starter #9
The car is a black vert with black interior and black rims with polished lip. Staggered. Going for the all black look in Florida...smart I know but its a weekend cruiser so whatever LOL
It's been cold here in Florida lately so I haven't went outside much. (OK anything below 50 is freezing to me). Here's a few pics. Today I am going to wash her so after that I'll take more. This car I have had now for almost 8 years. It's got a build date of November 2000 and I've felt your pain nile LOL. I ordered the wrong clutch and flywheel because I went off the 2001 spec but since it was built in 2000 it uses the older bolt patten.
Anywhere here's a few:
Here's a pic after detailing the engine bay. I scrubbed the 18 year old crud off the hood and detailed everything. Only thing I need to do is take off the hood liner, scrub and hose it down, and repaint it with fabric paint. The EGR valve is also rusted so I need to sand and paint it black. Here you can see my red top, accell coils, strut tower brace, airaid CAI, C&L plenum, BBK TB, caster/camber adjusters, catch can, ect. Not bad for being 18 years old. Everything that should be new is new right down to the idler pulleys. In the background is a box from Lloyd mats. That's a new trunk carpet. I have to totally redo my trunk. It's kind of a mess and looks bad. When the trunk weatherstrip failed water got in. Mix that with the Florida sun and going unnoticed for weeks and I got a mold problem. Ripped everything out, bleached it all down to kill mold, and had to cut a piece of wood to replace the stock to go over the spare tire well and bought fabric from joannes to attempt to match the OEM color - I failed. I also used too thick of wood. New plan is to get thinner wood and recut it then lay the Lloyd mat over it for that OEM look again. Then redo all the wiring and mounts for my subwoofer (10" Alpine Type R ported) and remount the amps. Redo all the wiring so it looks more professional.
Here's where the BBK Ceramic long tubes meet the midpipe. I painted the BBK O/R H pipe black prior to install for rust protection purposes. You can also get a glimpse of the MM FLSFC welded up.
This is a peek of what you can really see of the long tubes from looking in the engine bay. The BBK logo. You can also see the accel super coils better. I also repainted the stock valve covers with black high temp grill paint. This was taken before the detail and brace installed.
I'll take more today.
Discussion Starter #10
More if anyone cares
-Raxiom 03-04 LED Tail lights (Off and when the headlights are on. Didn't get a pic when brakes are applied)
-Borla Stinger Cat Back exhaust - you can see how big the 4" tips are
-Red inserts in bumper
-Staggered wheels - you can see how fat the rears are
-Tinted LED third brake light (ebay)
-Spoiler delete
-Sequential blinkers (ebay splice in special) with raxiom plug in module to slow them down (not shown but its in there)
---------- Post added January 30th, 2018 at 12:09 AM ---------- Previous post was January 29th, 2018 at 11:54 PM ----------
Reverse glow gauges, billet headlight knob (old one was cracked), white face AC with billet knobs and re-wrapped steering wheel with new leather (stitched on) from Leather Steering Wheel Covers Manufacturer and Distributor. Went Euro-Perf on the sides and standard leather on top and bottom (time consuming to install right). Also get a peek of the cheap AM pedal covers. The stock plastic ones were breaking and deteriorating.
Beltronics MAX360 radar detector hardwired into the ignition. Mounted to the rear view with a ebay version of the Blend Mount (knockoff)
https://www.ebay.com/itm/RadarMount-Car-Mirror-Mount-Bracket-For-Radar-Detectors-Escort-Beltronics/322264354885?epid=2164378522&hash=item4b0873d045:g:2R0AAOSwPCVX3Jop
MGW shifter
My favorite knob - cue ball design with mustang logo. I tried the ever so popular FRPP shifter but found this to be more comfortable and I could shift quicker with it. Felt MUCH more natural.
Discussion Starter #12 (Edited)
Thanks Mike. Again I don't want to cloud clubhouse with it but projects section was moved.
It's a car I tinker on in my free time. It's paid off and a car I rarely drive but I love it and it helps relieve stress and brings enjoyment even if it isn't a wild build. Just a weekend mechanic working on a weekend car.
I made it to track personal progress. I see in the 2v section new people all the time so I guess I hope it helps them too. I'll post more pics as I take them to give others ideas of things I've learned personally over the years. Crazy to think I've had this car almost ten years now. I just take care of what I got and refuse to buy new just to let it sit. I literally pay gas and 75 bucks a month to own this car. More money for mods. Currently saving and researching a vortech build. Just need to get parts I already own installed first. As you can see on the shelves in the pics I have a lot. Most of that stuff is random parts. Just requires time that I don't have a lot of.
Discussion Starter #14
It's literally impossible to cloud the clubhouse these days. Keep posting **** here, it won't offend anyone. Except maybe @WickedSnake00 since your mustang actually runs.
It really is a ghost town. I remember when I couldn't keep up with it and the 2v had a page of new posts every time I hit refresh. Is the 2v section keeping this forum running? Lol
missippi roolz
I've never come across a forum with better 2V tech info than MM so maybe.
Keeping posting as brtnstrns said. Maybe somebody new will see this and it may help them. I know I'll be looking at threads like this and others once my engine gets fixed or replaced. There are a lot of things I need to do to my car. 10 years is a long time to have a car nowadays, seems like people get rid of them when they get a few miles on them. Instead, they could save money in case any major problem and save themselves a ton of money over the years. Anyway, keep posting away!
Discussion Starter #17
I can see why people get rid of cars after a short amount of time. Who has time (or even the mechanical skill for that matter) to do repairs? Luckily my car is not a DD. If it were, I'd have no choice but to get a DD or if I had to - sell the Stang for it. I live in a city where public transportation is non-existant. Who has time to deal with repairs with hectic lifestyles? I work on my car at my leisure so I can do it. I couldn't imagine an issue Monday morning that would put a dent in my entire schedule. I know some less fortunate people that drive complete junkers. They have had to call out of work or walk places because their car failed, had no ride, and had to get to work.
I know I've had to get to shops during business hours because they aren't open late or on the weekends. That's hours out of my day where some employers wouldn't allow that. My job is flexible to where if I get my work done I'm good. 8-5 people would be screwed if they were out of vacay and sick time - using it up to deal with car repairs. Now throw in shady shops and insane repair bills. Ah!
Anyway - I'll post more. Going to tear into it not this weekend but the next. Bought new lower MOOG control arms to because of the bushings. Currently looking for some new shocks and struts. The ride is not where I'd like it. While I'm not slammed (1.5" drop) I am lowered and the new shocks and struts don't like it (I have Monroe Sesatracs all the way around with less then 4k miles on them but these are for OEM stock height).
Bought new wheel bearing assemblies up front just because I'll already be in there, had AM store credit, and they are stock. Going to replace them for peace of mind.
Ah the list goes on ... these old cars I swear. Throw in modifications and it's just a joy isn't it?
1 - 17 of 17 Posts
