1 - 1 of 1 Posts
FRONT SUSPENSION
Front shock absorber upper nut: 74 lb-ft
Front shock absorber-to-spindle nuts: 148 lb-ft
Shock absorber upper mount-to-body nuts: 30 lb-ft
Shock absorber upper mount-to-body bolt: 30 lb-ft
Wheel hub and bearing retainer nut: 258 lb-ft
Stabilizer bar bracket nuts: 52 lb-ft
Stabilizer bar link nuts: 14 lb-ft
Anti-lock brake sensor bolt: 53 lb-in
Anti-lock sensor wire bracket nut: 21 lb-ft
Ball joint-to-front wheel spindle nut: 129 lb-ft
Front suspension lower arm-to-body nut: 148 lb-ft
Tie-rod-to-spindle nuts: 41 lb-ft
Steering gear-to-crossmember nuts: 52 lb-ft
Wheels nuts: 95 lb-ft
REAR SUSPENSION
Front shock absorber (upper attachment): 30 lb-ft
Front shock absorber (lower attachment): 59 lb-ft
Shock absorber clevis bracket-to-axle nut: 80 lb-ft
Upper arm-to-frame bolt: 72 lb-ft
Upper arm-to-axle bolt: 82 lb-ft
Lower arm-to-body attachment bolt: 111 lb-ft
Lower arm-to-axle bolt: 111 lb-ft
Stabilizer bar-to-lower arm bolt: 41 lb-in
Parking brake cable bracket: 41 lb-ft
Axle damper front bolt: 66 lb-ft
Axle damper rear nut: 66 lb-ft
Axle damper bracket-to-frame bolt: 59 lb-ft
Pinion bumper mount-to-body bolts: 10 lb-ft
Bracket assembly-to-differential housing bolt: 35 lb-ft
BRAKES
Front caliper bolt: 64 lb-ft
Caliper bracket bolt: 85 lb-ft
Brake hose bolt: 52 lb-ft
Rear caliper bolt: 26 lb-ft
Caliper bracket bolt: 76 lb-ft
1 - 1 of 1 Posts
