1 - 3 of 3 Posts
Thinking about selling my 2003 torch red 10th anniversary vert with 50k miles. clean title and has tons parts what would it be worth with and without drivetrain? Im still torn between selling and rebuilding.
Mods
McLeod rxt twin disc 26 spline
Ram billet steel 8 bolt flywheel
tremac t26 spline input shaft w/ Lp throwout bearing ford racing bearings
Reische Performance FORD-4D 170deg Performance Thermostat
NGK TR7IX Iridium Spark Plugs
Maximum Motorsports 82-04 Mustang Firewall Adjuster, Quadrant and Cable Kit
Mgw short throw shifter
Rotopro rotors
Russell 99-04 Cobra Braided Stainless Steel Brake Lines
Maximum Motorsports 99-04 Cobra IRS Rear Spring Isolators
Maximum Motorsports 84-04 Mustang Urethane Front Spring Isolators
Koni yellow double adjustable shocks
H&R Race springs
MAXIMUM MOTORSPORTS CASTER CAMBER PLATES
STIFFLERS FIT SYSTEM CHASSIS STIFFENING KIT
STIFFLERS LOWER CHASSIS BRACE
Fully built FTBR rear end ford performance 3.55 gears
Level 5 dss half shafts
Magnaflow magna pack cat back custom
Metco 03-04 Cobra Alternator Pulley 2-4lb Lower Pulley (3.20")
Whole car is sound deadened
Extended wheel studs in rear
Custom speaker system
Jlt ram intake
Auto meter A/f and volt gaues
Rebuild it and keep it. You won't get out of it what you really want. Same thing happened to me with my 01 Bullitt. Didn't get nearly what I thought it was worth.
Save it. Build it. Keep it for a long time. 10th anniversary edition too? That's a keeper.
1 - 3 of 3 Posts
