1 - 11 of 11 Posts
Speedometer Acting Whacky It Works Then Stops And Drops To Zero Then Park IT For A Little Bit And Drive Then It Works Then Drops To Zero Now It Stopped Working For Good
How Would I Go As Trying To Find Out What The Problem Is Because I Had The Same Type Of The Problem With My 2003 GMC Yukon It Was A Bad Stepper Motor The Little Motor That Drive The Needle On The Cluster Had Gone Bad But They Had A Recall On Alot Of GMC SUV's Just Becuase Of That It. Are Mustangs Still Cable Driven For The MPH Or I Heard Something About The Gears That Turn The Needle MAy HAve Gotten Stripped?
It's most likely the speed sensor located in the tailshaft of the tranny.
Hmmmm Well Here An Update The Next Day It Started Working Fine And Just Today I Was Doing 65 On The Freeway And It Dropped To Zero If So Do You Guys Still Think Its The Speed Sensor Because Im Going To Go Pickup A New One Tomorrow And If I Buy A New Cluster Will It Mess Up My Milage
1 - 11 of 11 Posts
