1 - 14 of 14 Posts
not sure, but:welcomeanyways
N/A 4v Guru
I know I know, just f-in with the new guy:D If no one has told you within the next 20 minutes I will let you know. I gotta run out to the car in the parking lot here at work. Be right back.
amateur adult film star
well its in a fuse box i beleve its under the hood but the owners manual should tell you what fuse and where
Sorry, I am new to this forum. I just got this mach1 and the abs light is on and was told the fuses were pulled by the seller. All fuses in the fuse box under the hood look good, one was missing which I replaced(traclock). Also I didn't get a handbook with the car. So seriously, does anyone know of a possible other location or connection to check? thanks
traclock should be your abs so you may have a seprate problem
N/A 4v Guru
Under the hood fuses
Position 8 50a
Position 17 20a
Under the dash
Position 29 15a
exactly what it sounds like they are on the drives side above the pedals
Thanks, found it and put the fuses back. That fixed it
Right on. Just out of curiousity, why exactly did the owner pull the fuses?
1 - 14 of 14 Posts
