601 - 620 of 642 Posts
my car has 165K so that cobra is already doing better. I hope my car makes it way past 200K also. At least enough time to enjoy my mods without having to rebuild it
Discussion Starter #603 (Edited)
Yes i still have my Rio Red 2v
With that out of the way, here's the 97 cobra i recently picked up cheap... its got some issues lol but i don't plan on keeping the car i plan to fix it over the winter, driver it for a bit and sell it come spring. figured id post in here to show those who follow my thread. I'll make a thread for this car as well just not sure if i should post it in the 96-98 section or the 4v section of the forums. Anyways here is the rundown
the good
- 1997 Pacific Green Cobra
- Clean title
- Cheap
- 138,617 miles
- Seemingly rust free
- BBk intake, Jet MAF, BBK 65mm TB, BBK long tube headers, MSD plug wires, catted midpipe (cant remember if its a H or X), and some sort of cat back
- Found a steering wheel cover, motorcraft oil filter, 4qts motorcraft sythetic blend oil and two jugs of coolant in the trunk! (These could be warnings of possible issues i guess)
The bad
- Needs driver side head light (lens is cracked)
- Need to remove all the stickers lol
- Needs rear quarter fixed
- Needs clutch
- Needs steering column (will go more into that later on)
- Needs PA state inspection & Emission
- Find & fix exhuast leak
- Front and rear bumpers could use a respary
- Small hole in driver side seat
- Hood latch sticks horribly
- Hood is lose and zip tied on... :shiftyeyes
- Weak, yet new battery
Looks like a promising project. Engine bay could use a nice cleaning which I'm sure you're planning on doing.
I wish I bought a Cobra! I love SN95 cobras.
6 Cylinduh, Really Bruh?
the good
- Clean title
- Cheap
- 138,681 miles
The bad
- Needs clutch
Whew good luck man. Hopefully there isn't hidden surprises lurking. The stuff in the trunk would worry me
Discussion Starter #606
To anyone who wants to follow the cobra progress i've made a thread in the 4v/SVT section - Click here -
I've always like the SN95 cars, the softer lines over the hard boxy line on the New edge are a nice change, but i still love my New edge! and oh yes the engine bay needs a detail badly!
With any project car, hope for the best but expect the worst!
Discussion Starter #607
Not much of an update, i've been working on the 97 cobra recently for those that want to check that out. However i am having a new issue with my 99 GT. between 1,500 - 2,000 RPM's under light throttle input i notice the car "bucking." if i give it more throttle or let off completely the bucking goes away, this has been going on for a month or so now. I've notice it only does it once its warmed up as well. I don't know where to begin or even what to monitor on the SCT X4 as it isn't throwing a check engine light, however i do have a CEL for passenger side front 02 sensor being lean from an exhaust leak where the midpipe meets the header, but ive had that issue for a while now.
Check the COPs, COP boots or spark plugs.
When my '99 did that a couple months ago, there was water (from the heavy rain we were getting) between the COP boot and plug in Cylinder 1. The boot was old and didn't seal well. I dried it out and replaced the boot ($7) and used some dielectric grease between the spring in the boot and plug. Fix it right away.
Hope that helps.
Discussion Starter #609
Hope that helps.
Wow i didn't even think to check the COP's lmao ill check them this weekend thanks! :thumb:
Discussion Starter #611 (Edited)
It's been some time since i've updated this thread, the mustang is still going strong about to tick over to 214,000 miles. I've started a new job that required a lot of driving, about 65 miles a day or more depending on where i have to go. The company car they gave me began overheating so I fired up the ol' trusty steed not caring about racking up the miles on it. unfortunately at some point in my 65 mile commute the alternator bolts that screw into the block decided to snap. I would have never noticed this unless i stopped at the parts store and bought a can of AC recharge. one bolt is somewhere on the road the other wedged itself between the block and the water pump pulley slowly grinding away. luckily the pulley and belt look fine. i'm just surprised that the alternator bracket itself was able to stay in place and not bend downwards with all the tension from the belt. It sucks that i now have to drill and tap the screws out but it could of been worse, could have left me on the side of the highway
P1SC & build motor is still in the works just waiting to find time and room in the shop to get it done, along with finishing the 1997 cobra i bought as well lol. Also trying to go back through my threads and fix the pictures since Photobucket royally screwed a lot of people.
Discussion Starter #612 (Edited)
Finally getting around the my built 2v motor, just mocking things up as im forcing myself to make time for it this winter. Installed a high flow Edelbrock water pump for cheap insurance of not overheating. probably a good thing i did as i didn't realize how nasty the old one was. Also went to set the P1SC in place just to see how it sits and what not and quickly notice it's not facing the right way, i can just take the bracket off and rotate it correct?
Discussion Starter #613
Update!
I've had my 200,000 mile pile for 4 years to the day :drink
Now to the actual update lol, I've finally got the time to get to work on this thing, reclocked the P1SC which was stupid easy to do not sure why i was so afraid to do it lol. Earlier this week I ordered all new bracket hardware and a 3.6" pulley from Brutespeed which is a super helpful company by the way. With the 3.6" pulley i'm shooting for 10-12 psi, is that doable? the other question i have is does anyone know what belt size do i need with the 3.6" pulley? Now the reason i ordered all new bracket hardware was because the more and more i looked at it the more i felt like it was missing bolts so might as well have all the correct parts with possible extras. Anyways I've hyperlinked the installation instructions for the P1SC below as what i've typed is probably confusing lol. Now back to the bracket installation hardware, I havent opened the bags up because i'm completely confused by the bolt with all the bearings already on it(took a close up picture of it below) i understand it threads into the passenger side alternator bolt hole (page 6 letter C in picture) but there is two issues with that. #1 the bolt looks to be way too short to be able to thread in and stay inline with the rest of the pulleys, i don't know maybe i'm wrong? issue #2 is that in the installation picture for this bolt on page 7 shows there are two different idler shafts that are on each side of the pulley, which is fine. the issue is the shaft after those two idler shafts that is already threaded onto my bolt. It doesn't show that shaft in the picture on page 7 at all, nor does it list this "shaft" on the hardware list, in fact this bolt isn't on the list either :headscratcher:. Now the bolt that is in the last picture below that is threaded into the passenger side alternator bolt hole is one that came with the P1SC when i bought it, and it fits just fine which only confuses me even more. Hopefully you guys can help me out
P1SC install instructions 1999 Gt instructions on page 6&7
Discussion Starter #614
Alright alright alright I need to update this thread more often, unfortunately I don't have many interesting things to update it with, unless you guys just want mileage updates lol. Anyway It's been nearly a year since my last update on my 200,000 mile pile. Yes I still have it and yes it's still going to get that motor/P1SC.. at some point. I have to finish my stupid SN95 cobra project before I take on another. Over the past year i've just been driving and enjoying it. Had a tire blow out and completely shred from the back of the wheel so that was fun. Somehow I ripped the E-brake bracket out of the chassis mount as well. Also thanks to lovely Pennsylvania weather over the years and a leaky brake master cylinder I found strut tower rust :sorry Probably the most interesting this I did with it since the last update was that I took it out for its first auto-X event!
E-brake ripped out of the body
Usually I take my Mazdaspeed3 when I auto-X but at the time of the event it still had its all-season tires on and was due for an oil change. Enter the ol' reliable mustang, Having never autocrossed a RWD car before I wasn't sure how I would like it or how it would handle since all i've ever heard was "Muscle cars and corner." But now I think I honestly prefer how the mustang felt out on the course compared to my Mazdaspeed3! If someone can tell me how to embed video i'll upload an auto-X run.
However my first auto-x experience with the mustang was not without problems.. at some time during the race the battery light on the dash came on, I didn't notice it until I was finished my last run, didn't think much of it as I thought maybe a ground wire came loose or something. I then noticed my voltage gauge a little lower than normal so I plugged in my SCT and it was around 12.8v and holding. I figured I could limp it home and figure it out later. about three miles down the road and the voltage dropped and the car started bucking and backfiring like crazy. Had to get the car towed because even with a jump it wouldn't stay running long enough to limp it anywhere. The cause was a bad alternator, I guess it overspun/overheated it while racing? Who knows, all I know is this is the 4th alternator i've put in this car in the past 5 years. Luckily since I bought the 1st alternator at a local parts store with a lifetime warranty, I just bring it in and exchange it for a new one for free.
But wait it gets better! the next day after the race while im swapping out the alternator I notice a small pool a liquid on the ground. I must have cracked the plastic end tanks of the stock radiator while racing and it slowly dribbles out. The odd part is, it leaks randomly. The autocross event was back in May, and it hasn't leaked again until today. I have a Mishimoto aluminum radiator sitting with all the other parts for my motor/P1SC swap. So i'll take care of it at some point
With that said, thats all thats been going on with my 200K GT. It's currently at 216,4xx miles and keeps on ticking. I'll try to update this thread more often, maybe one day ill update with the motor pulled out!
Discussion Starter #617
You may not like what you see when if/when you pull that engine and poke at those strut towers. I'm still chugging away on a rust project like that that spun out of control.
And my heap did the same with the ebrake when I got it. Nothing a washer can't fix, right?
Yeah, im not looking forward to the strut towers. Preparing myself for the worst but hoping for the best lol. I didn't think of using a washer for the E-brake! gonna have to try that
Looks great for the miles! Actually, looks great regardless of miles.
Thank you!!
Discussion Starter #618
I know this isn't related to my 200,000 mile Mustang or even Mod motor related and since I don't really know where to post this lol. I picked up a garage find 1965 Mustang yesterday!
Info
1965 Mustang
77,794 Original Miles
289 C.I. V8 2bbl
Auto
Power Steering
Air Conditioning
Wow nice find! Looks to be almost rust free. How are the floor boards and the interior?
Discussion Starter #620
The interior is really clean! no rips in any of the seats, one tiny hole, maybe the size of a pencil tip in the headliner. The metal trim is pitting but for the age its in great shape and everything works! even the old school AM radio. As for the floorboards and rust, with the fact that is 53 years old and has been inside a garage since the early 90s it's honestly not bad. It definitely has some rust, there is one hole on the driver side where your left foot rests. There is also rust here and there, but i've seen much worse. I just noticed this forum has a classic section i'll probably create a thread over there about it
