Conversion Info
Job Time: Approx. 2.5 Hrs
The process is good for the following:
Bumper replacement
Hood Removal (with the washer lines in the hood)
The tools used:
* Phillips screw driver
* Flat head screw driver
* 1/4" socket wrench
o 5mm socket (Lower shield)
o 8mm socket (Left & Right GT500 mounts)
o 10mm socket (GT500 Air Splitter)
* Rivet gun (4) rivets
Optional:
Tool for removing plastic push pins
Recommended Parts List:
* Front Bumper Assembly
* Front Air Splitter*
* Front Grille Assembly
* Lower Grille
* Center Bumper Support**
* Left Conversion Bracket*
* Right Conversion Bracket*
* Isolator Assembly
* Front Grille Emblem (optional)
* 2 Fog Lights w/ Bulbs / mounts
* Fog Light Wiring Harness
* GT500 OEM Hood
* GT500 Radiator cover
(Optional) Radiator Air Deflection info
Bumper replacement
The tools used:
Optional:
* Lower Grille
* Isolator Assembly
* GT500 OEM Hood
