It is possible, he need to swap over the upper intake plenum/tb/exhaust manifolds/ and wiring harness/coil packs from his mustang. It will give him a decent bump in power too. Should be able to retain his Mustang flexplate/flywheel since it will most likely be a 6bolt crank in both engines.
He will have to drill and tap the coolant crossover on the '11 Engine for the second ECT Sensor that is found on 96-98 GT NPI Engines.
---------- Post added at 03:43 PM ---------- Previous post was at 03:36 PM ----------
He will need to switch his fuel rail as well since his 96 is return style and the 11 is returnless.
