1 - 11 of 11 Posts
I've been looking around for some struts to go with springs I'm getting for my 2011 V6 PP, and I've been wondering: What are the differences between the 2010 and 2011 S197's that'd explain why there are so many struts and caster/camber plates that exclude 2011+ support? Is it solely the differences (heavier...) created by the new engine platforms?
For instance, Evolution Performance lists the Tokico D-Spec strut kit (DSP-12) under their 2011 V6 parts.
However, on the Tokico website/catalogue, all products "2011+" are "In Dev". I imagine this all comes down to Tokico wanting to tune in their product quality, and some vendors wanting to sell what still works; right? Are there differences between the 2010 and 2011 suspension at the strut tower ends? And yes, I did at least go through four pages of different google searches before asking that last question. ;] I'm certain it all comes down to the weight factor, I just want to make sure, in case I jump into the pool and make things work out with some nonspecific parts.
Also, I have a strut tower brace - noticed a lot of caster/camber plates come with particularly short bolts, should I just reuse my stock bolts if I upgrade those? Or purchase new bolts from HDR?
For 2011 you need to switch to gt500 strut mounts for 2005 + and then you'll have no fitment issues.
I lowered my 11 with the Roush lowering springs and broke the stock mounts a few miles down the road. I finally got my hands on some GT500 mounts and the stock Struts don't fit. So yesterday I ordered Koni Str.t (20% right now) and Steeda Sport Springs. Lots of people have said its a great combo. From what I have learned the weight difference requires a change in springs from 2010 to 2011 but the struts for the 2010 work great.
I also ordered panhard bar and LCA brackets from BMR.
Nice, ya, I did eventually get the whole spiel on GT500 mounts and incompatibility with our stock struts (but wut about GT shocks? D:).
I think I'll end up waiting it out for some 2011-specific struts, can only really hope that they'll fit together at this rate, right?
Where did you order the Koni's from and do they have them in stock? Everywhere I've seen has them on backorder at the moment. Makes me wish I had ordered sooner even though I won't get my car till June...
Token asian guy
The strut and upper struts are different from '10 and older. I have Koni STR. Ts and using my stock upper strut mount mated to my MM CC plates and I haven't broken them yet.
Strano Performance Parts - Part Details
Thanks for the link, I have to give him a call in a few hours but I'm pretty sure he's out of stock on the fronts. Oh well, have an entire suspension coming in from him so might as well get on the list. Should be fun with the Koni's, steeda sports, and Fayes2 Watts link. Might have to stop by Oceanside to see your car before I take mine from CA to VA
FCMalie, I just talked to Strano a few minutes ago and he is out of Steeda's but has more coming early next week. The Koni's are out as well with no ETA, but he mentioned the fronts he could get his hands on easily. I found another company here in Washington that had 1 set of Koni's left and they are now on the way. I bought my Steeda's direct and they are also now on the way. Can't wait to get my car back together and drive.
Yea, luckily I won't be getting my car till June. Still a bit of time to get them. I guess I could always wait till later to install them. Couldn't make the call today, but will try tomorrow and just ask him to ship when he gets them all. No big deal. Guess I could always see if he suggests anything as much as the koni's.
Discussion Starter · #10 · (Edited)
Wait, wut?
You blew my mind here, quite a bit. I actually had to stop and reread a few online sources and diagrams on suspensions. AFAIK, your CC plates were replacements for your upper strut mounts. What you mated to your plates was probably your stock spring receiver?
[edit]BTW, I got my answer: The 2011+ struts have removed 1.5" of nonthreaded shank. See Pg. 7 of this install guide http://www.maximummotorsports.com/content/install/pdf/front_susp/Mm5CC-6.pdf
[edit:2]I meant spring perch.
2018 Mustang GT Manual
I lowered my 2011 and used the stock upper mounts and stock shocks and I've already broke 1 of the mounts. As soon as I get new shocks I'll replace the broken mount.
1 - 11 of 11 Posts
