1 - 4 of 4 Posts
Just curious, can I run a 20a bap on a dual pump setup? How much of a difference is a 40amp vs a 20amp? This will be run on 2 division x Stryker 340lph pumps, modded fpdm, and 80lb injectors.
I'd rather not chase down a 40amp bap, but if I have to I will.
Also, I'll most likely be running an e85 tune.
Wiser by the Minute
NO - I'm pretty sure you can't but someone chime in please.
I dont know what kindve power you are looking for but dual stryker pumps with a wire upgrade and dual fpdms will get you 700 easy on 93. Thats without a bap. So if youre not going to have more than 550 id say forget the bap
That's what I thought. I think I'll just keep the 20amp bap on there. And no idea. I've seen people with the setup I'm going for clip 600rwhp but less aggressive heads, and I'll probably be upgrading to an si trim. I'm not sure what it'll make on pump and e85. I'd like to clip 650 on e85.
1 - 4 of 4 Posts
