1 - 12 of 12 Posts
So im lookin into getting new rims and i have decided to run 17x10.5s on the back. Would a 17x9 fit on the front with 275/40/17 tires and not rub? my car is lowered an inch if that helps but they seem a little too wide and i dont want to buy them and have them not fit.
Abyssinian of AX
275's tend to rub a bit :yes
Some pepes have no issues while others have some, just too many factors to consider to know. I recommend a 265 for a better fit, IMO, but will be safest to address the protruding tabs of your front fenders reguardless of what tires you get when going to a 9" wheel up front.
Jazzer :)
What he said.
I have 265/35/18 going up front. Not mounted yet, and I'm already worried something is not going to fit right.
Abyssinian of AX
HEY..... I am a lady! Thank you very much
Abyssinian of AX
... jus' playin' :yes I'm a dood :D
Abyssinian of AX
265's are a good fit, for a 9" wheel :yes
I have found that a 275 is a little fat, even though rated to fit a 9" wheel, and tends to roll-over on hard cornering and looses grip. If you were really aggressive on corners I would recommend a 255 or even a 245.
Jazzer the ambidextrous kitty :shiftyeyes
My 275s rub on right turn transitions. :( Should have gone with the 265.
Abyssinian of AX
Depending on where they rub, may not be an issue :no
If hitting the fender (there are some sharp edges under there that can cut), just bend them back out of the way a bit with some caution. Easy to do and nowhere near cutting the entire underside completely off, as I had to do. Cannot tell from the outside, but I no longer have fenders to roll :D
Jazzer... rollin' fatties :)
1 - 12 of 12 Posts
