1 - 14 of 14 Posts
Im planning on around 600 horsepower and im needing to know if i need to change everything to 31 spline or if 28 will be fine?
damn 600 out of what i want to know the combo!yes you will need at least 31 spline
i dont have the combo figured out completly yet but i was thinking a 347 with a twin turbo or a 408 with a turbo or something else but im not sure yet.
33's are same money, been using them for the last 10 years
yes but i didnt know if he wanted to go with a spool or not man.
if you do the 347 i ope you have enough money ti buy an aftermarket block
my car is only running 260 hp. about 375 with nitrous. I broke my drivers side axle, I did the burnout then staged then at take-off I only moved 6 inches there I sat. It dosen't matter as much about hp as it does with your traction. So i've got my moser spool and 31 spline axles waiting in the garage. I'm running mickey thompson drag radials I guess they are hooking good.
That sucks, I ran 11s with my stock axles for 4 seasons before I upgraded.
launching to hard:eek:see what happens:D
1 - 14 of 14 Posts
