1 - 5 of 5 Posts
okay if i buy a 2v 5.4l shortblock with fully firged internals tickflow twisted wedge heads and a custom grind cam would i make more than 400 hp all motor? and how hard is it to swap in a 5.4l 2v motor into a 04 mustang gt 5speed ?
btw i searched and nothing
I'm cool..
It can be possible, but you might fall short. The torque would be awesome. Its a hard question to answer because there isnt enough data on those heads yet. The heads just came out last month. Food for thought though 2000 Cobra R with custom cams will break 400 rwhp... Those heads flow the same, now you need a cam large enough to rev the car to the moon and second have a bottom end capable to be revved.
I dont think the 3650 bellhousing can be removed.. you have to go T5 or T56.. and yes it goes in.. you will need a cowl.
3650 bellhousing can be removed, the T45 is the one thats all in one.
The cobra r was also a DOHC, not a 2v like hes talkin about
on the 2v youd prob see mid 300
330-340 and a lot of torque
If you use a stock 4.6 oil pan you have to do some small taping on the front side of the sump. Other wise it just drops in
1 - 5 of 5 Posts
