21 - 27 of 27 Posts
Discussion Starter #21
yeah good ideo..im just swapping a 4v motor into minie and forging it and a lil head work..
7.62x39 CO2 Cannon
If this 3v swap is cheaper than a 4v swap, I think it will be worth it. If not, it may be easier to just add a blower, or for equal complications go 4v.
The Hammer
:kneel
yea youll need to modify the mount that the main difference between 05 and up and pre 05 blocks
Only diference in the block is that it is aluminum. You dont have to mod a thing. You need an adaptor kit to run your new edge exhaust manifolds/headers and 03-04 cobra throttle body. Not only is the 3V easy and cheaper than a 4V, the heads damn near flow the same. The motor is also lighter.
21 - 27 of 27 Posts
