1 - 2 of 2 Posts
This is my first time on the forum and i'm trying to help out a good friend.He took a v6 out of his 94 and put in a 4.6.After researching about this swap I realize this swap is not worth the aggravation.Anyway we changed the computer and the engine harness on the 97 we plugged into the 94 harness.We had no spark so we put a hot wire to each coil and solved that issue.The car will only fire if we put fuel in the intake and the fuel pump kicks on and we have pressure in the fuel rail also.We are not getting any fuel to the plugs though if anyone could help that would be great.
So your saying no fuel is getting to the combustion chambers? Are the injectors working or do you know? And how did you rig this whole spark problem up, sounds sorta sketchy
1 - 2 of 2 Posts
