No way, not even close. Gt's cant even make it to 300 whp without full bolt ons and a good set of cams.
you fail
so do many threads. ITS beyond EASILY possible to hit 300whp all motor.
On pump gas probably not happening
and theres no 10second v6 mustang n/a he runs 11.8s on motor and 10s on bottle (125shot) made 260rwhp and extremely similar torque.
THERES SO many ideas UN-USED. I can garuntee you with enough money I could build you a 350rwhp all motor V6. EASILY TOO!
if 4cylinders are making 354whp all motor you must be nuts to think a V6 cant
so many things havent even been attempted on these cars
a v6 with individual throttle bodys has incredible potiential. your first fuel rail then a secondary above the velocity stacks cools down the incoming are the stack and tube and generates more power. high compression with Q16 not the baby C16 stuff. 4.3L stroker with a well specs big cam and some worked heads. then just a manual t5 tranny and 7.5 rear.
someone made 260whp with just a windstar intake, mild cam, a C4!!! and pump gas. just switching to race gas and a manual tranny you'd see your 300whp goal...
now will you run 11.8s lol
