1 - 11 of 11 Posts
so i am thinking of getting some 315/35/17 for my 10.5 inch rims and was wondering if they will fit under a stock body (fenders arnt rolled) and if not how much rubbing will occur.
My 315 35 17s were fine with a 1.75" drop - only rolled my fenders when I stepped up to 305 35 18s
Here was the 315s
Super Moderator
Here is my 315 with 1.75 inch drop. I actually want them to be lower, BUT my coil over in the rear is as low as it will go.
needs more boost
I haven't had any problems with mine :dunno I think you should be fine op. If you run into problems later you can always just roll your fenders.
GT 4.6 SOHC
I had my 99' 2v vert with a 2.5 + inch drop with 315 on the rear on stock 99' 17 inch rims. Worked just fine even with 4 people's in the car. Only thing I did not like is how the tires needed to bulge out considering the wheels were small in diameter.
Give it a try and let us know!
GT 4.6 SOHC
If you get spacers, then consider the option of rolling the fenders!
17's will b fine 18'sare ify. I need to have my fenders rolled..
My old mustang which was a 2000 had 315/35/r17's on a two inch lowering and cleared fine. Also skidad what tips are those in the sec pic?
1 - 11 of 11 Posts
