1 - 20 of 66 Posts
I guess im going to go with the stock 302 and turn it into a 347 stroker... this is my first Mustang and my first engine rebuild I've been reading other threads there good info here and there but its spread thin...
I've been looking at the Scat stroker kits is there better kits out there?
And whats the difference between the 5.4 or the 5.325 connecting rods?
what needs to be done to the motor to shift at 8,000 RPM or is that N/A out of a stock 302 block? Or is there no gains at that RPM?
Not looking to start any arguments or abuse just looking for good info to build my motor thanks for any help!
Powered by LSx tears
Here the deal man....you need to decide how you want to do this. 302 blocks aren't that strong, so do want a power adder, or N/A? If you're wanting a power adder, I think you're better off staying with a 302, because it's cheaper and very easy to reach the blocks limits. If you're wanting in the 500 bhp range N/A, then a 347 is great. First thing to know, is when you're looking at parts, throw the advertised power range out the window.
You need big heads and intake, and a good cam. I would advise a TFS-R intake, and a set of TW185s, with a good custom cam. I've used Bullet cams and been very happy with them, but there are some other good places.
If you're wanting to push those kinds of numbers, you need good parts, and a good tune. Scat makes a good rotating assembly, and would be a good choice. I would advise to start with a budget, because you're looking at a pricey build.
Well that's what im asking what RPM is safe to shift at?
And what is the difference between the 5.4 Rods to the 5.325 Rods short stroker kit?
Normally a 347 with a 5.4 rod uses a standard ring pack and puts the piston pin hole into the oil rings. With the 5.315 rod they use a 3mm oil ring and the piston pin does not intersect the oil rings, supposably for longer life??
I'm not wanting any power adders I want to build it all motor 475 to 500 at the crank...
What's the differences between TFS-R intake is the TFS-box-R intake better?
The 5.325 stroke would either be used with a larger bore (4.125) to make a 347, or it can be used with a 4.030 bore to make a 331. The 5.4 with a 4.030 bore makes the 347 you want, because a 4.125 bore isn't an option with your block.
As far as RPMs, i wouldn't press it past 6700-6800, but that all depends on how well you build it. It needs GOOD valve springs, and be full of ARP hardware. The main caps are bad about chattering under a lot of RPM, and ultimately causes e block breakage, so ARP bolts are a must.
Do you lose power with the 5.325 stroker?
The short answer is yes. If you build your engine right, you can always measure your power in hp/CID. There's a lot of truth to the old saying "there is no replacement for displacement." There is no point in limiting your displacemtpent to a 331, when you can go to a 347 for the same money.
Its a good thing I'm not that sensitive, or my feelings would be hurt right now.lol
Your putting down AFR in one thread and now your putting down a 331 in this thread......I guess my engine is really going to suck....lmao;) J/K
I'm not putting down AFR. They're good heads. I think you'll see what I'm saying in my latest reply :). The 165s just don't compare,to the TW170s, because of the short runner, and the 1.90/1.60 valves. TW170s carry a 2.02/1.60 are just a lot better head.
gimme 2k and ill ship you my shortblock pan pickup oil pump cam, just slap on the other **** from your motor and roll. Boom
I know bro...i was just playing around....I wouldn't go with AFR 165 either....185 and up seem pretty good though....But i would have rather have had trick flow heads my self, well 185 or bigger though
Discussion Starter · #14 ·
I completely understand that just thought I would ask..
And I plan on building it will all ARP hardware and all race application rotating assembly
Proud American
One of the people I race with, he spins his 349 to 8100 everyweekend... Drives it home too...
He uses a 289 block on his builds though because they seem to be MUCH more stable at that RPM.
Yeah, there are people doing it for sure. I know a guy making 560rwhp on a stock block for 3 years now. It doesn't mean I recommend it, if you know what I mean.
Proud American
Yea I hear ya... all depends on how well its built.... I took my 351 to 7300 the other day.... shusshhh dont tell anybody hahaha
Like mentioned, the scat kits are probably going to be your best bet for the money spent.
Do a 5.4" rod. You may have problems with the 5.315" rod because it moves the wrist pin lower on the piston and apparently makes the tower longer and often you run into issues where the piston tower hits the counterweights on the crank. Just saw a thread about this last week actually and a guy who builds ford stroker motors for a living brought this to someones attention. Horsepower junkie is right, the reason they make those rod/piston combos on a 3.4" stroke crank is to bring the wrist pin out of the ring stack. But the oil burning issues 347's had have been long solved and you no longer need to use a shorter rod to make it work.
8000 RPM takes a lot of cash, and the parts you'll need to do it would make it foolish to put in a stock block. There's tons of power to be had from spinning up that high, but believe me, if this is your first build, I wouldn't shoot for the stars just yet.
Also, rod length isn't going to change your stroke. You get the appropriate piston for the length rod you choose. The stroke comes from the crank.
1 - 20 of 66 Posts
