1 - 15 of 15 Posts
So I'm still having the surging/stalling idle on my fox. I checked the vacuum and it is at 12 idling. I read that 15-20 is ideal but on the same token, cars with bigger cams will generate a lower number. Am I good with 12? I have a TFS stage 3 cam, Duration @ .050" - 236°/248°
Valve Lift with 1.6 Rocker - .574/.595
Lobe Separation - 110°
ported twisted wedge heads with a holley systemax 2 upper and lower. Also has a 1 inch intake spacer. it has 1.7 rockers too. Fuel pressure is at 30, heard that was a little low too. Could that be vacuum related? Let me know it I am leaving anything out.
12 is fine
You check fuel pressure with the vac line disconnected from the fuel pressure reg
Just put your thumb over the the hose running to the intake when you do the test.... so yes, plug it
Discussion Starter #9
Rgr that, thanks man. I also noticed alot of gunk behind the lower intake and it looks moist. Could that be part of the surging/stalling?
Is your pcv valve still hooked up and all the way into your lower intake ?
that's the port that's centered in the back right? I have what looks like a blanking plate. No PCV that I can see. Car has zero emissions equipment.
What are you using to relieve crank case pressure..... a breather on the valve covers ?
He of Long Wind
I use the pinch method to trace vac leaks in the lines - sometimes it works. Just setup your gauge and then take a pair of needle nose and squeeze the various vac lines around the engine bay. If your gauge jumps higher at any point, the line you just blocked has a leak.
1 - 15 of 15 Posts
