1 - 12 of 12 Posts
Where can i pull a legit 351 block from? Im gonna be building a 351 for my fox, and i want to know if one can be pulled from a bronco or something like that..
!FACEPLATED!
Anything with a 5.8 I would assume.
!FACEPLATED!
I will suggest one thing, get a later model block that has a one pc rear main seal. the 383 stroker I just built for my truck has a 2 pc and it didnt seal right so i have to pull it back out and change rear main
any truck or van from the mid 70's up to 1996
even a few crown vics in the early/mid 80's
i got mine out of a 69 galaxie.. more nickel in it back then, which supposedly you can get more bore out of it cuz its stronger, also works with my hydraulic roller cam
you can convert any block to roller or use the retro hydro roller lifters.
the older blocks tend to have a little more meat in the main webbings
1 - 12 of 12 Posts
