I was currently building my 306. I have a chance to to get a smokin deal on a 351w short block he says its fully forged 10:5:1 compression but is not sure on the internals.. So tom going to go an pull the oil pan an look at it..
For my current build I have brand new trick flow upper (heads. 1.7 rocker arms, push rods, lower an upper track heat intake 30lb injectors, 76mm maf an fuel rails, all new gaskets.)
So heres my questions.. Will all my parts bolt on to the block? ( I think I will have to replace the push rods) I know I need a new distributor, mounts an headers, oil pan an oil pick up..
If any one has any knowledge or experience with this swap any info would be greatly appreciated... Thanks
