408 on nitrous, 195 heads, shorties , foot brake , 100 % street car .
I know you guys are probably tired of seeing this but since the track's closed for the winter I don't have anyone to videotape me. I drive the car all the time but it's kinda hard to drive and record at the same time .
---------- Post added at 01:26 PM ---------- Previous post was at 01:21 PM ----------
What 351w headers have you guys used in your Fox swaps.
---------- Post added at 01:27 PM ---------- Previous post was at 01:26 PM ----------
What 351w headers are you guys using on your Fox swaps?
---------- Post added at 01:30 PM ---------- Previous post was at 01:27 PM ----------
I'm running a 358w. T-5. 8.8 in my '79 Merc. Capri using Doug's headers 1-7/8' long tubes that slip together and leak terrible bad at slip joints and have had problems getting gaskets for the adapter plate that attaches to heads.
---------- Post added at 01:32 PM ---------- Previous post was at 01:30 PM ----------
My DD is begging for a new clutch. ('94 5.0L, T-5 WC, 3.73 rear)
I was planning on getting this setup Ford Performance HD Clutch set but after calling a few shops,
I'm questioning it. They use Luk or Valeo clutches and it'll cost me about the same to use theirs vs
my list below. Using their I...
Recently installed a clutch pedal assembly and now the steering shaft sticking out of the column seems too short...do they slide in and out?
It needs to move out 1/2 inch for the bolt hole to line up with the shaft that has the u joint and rag joint on it.
I've tried putting a breaker bar on it...
I did talk to they guy at Hanlon motorsports back in April of this year but a lot has happened since then and though I have the printout of estimates for what we talked about, I still want to ask you guys opinion on if I need a 500 or 600? Car will be a 351 with the proper crank to make it...
I've freshly built all of my engine and I'm trying to get it dialed in, i took it down the road for the first time and i noticed that after first or second at high RPMs it would pop and bang like hell before it shifted- I think it's coming from the intake. sometimes i can rev it at the throttle...
