1 - 6 of 6 Posts
alright i need some help... i have a 93 mustang 5.0 and am in the process of doing a 351w swap into it... everything is hooked up and good to go at least i think so... but when i goto start the car it doesnt start... alright so heres the thing it starts if i spray either in the throttlebody and will continue running and i could drive it whereever but once i shut it off it wont start again without either... any pointers?
Resident Know-it-all
Wow. so when it starts, it runs perfectly? Have you set the timing with a timing light and the spout out? What all is done to the 351, what distributor, what cam, what intake, etc?
Is it carbed? Sounds like a carb that needs rebuilt. If it is fuel injected make sure when you turn the key to on, not start that you hear the fuel pump prime.
well its a stock 351w outta a 94 f250 stock H/C/I bbk headers 19lb injectors... just a budget build ... any help would be awesome!
What did you set the timing to?
1 - 6 of 6 Posts
