1 - 4 of 4 Posts
Is there ANY way to make the speedo/odo accurate again if you install 4.10 gear with AODE transmission? My local tuner said a gear tooth for 3.73 gear is as close as he could get but I'm wondering if there are any other tricks?
If you can get ahold of a speedcal tool like a Dallas Speedcal then yes you can otherwise probably not. I have 4.10s in my 87 Grand Marquis with the aod and have the same issue.
Sent from my iPhone using Tapatalk
Yeah, from what I've seen those Speed Cal devices are hard to find these days.
That’s the only way unfortuneately. You might get lucky and find a used one on ebay, they pop up every now and then.
1 - 4 of 4 Posts
