just had a few basic questions.. I'm currently installing a set of FR 4.10's along with a motive bearing kit, pinion, carrier et cetera. replacing stock 3.27's
I had a friend telling me that I don't have to change the side/carrier shims since I am using FR gears is this correct? just replace them with factory size shims.
Also am I shiming the new pinion to match the original pinion shim or what?
this is obviously my first gear job, it's just that I've read a bunch before hand but I keep getting conflicting info.
If anyone can post a link or something to a howto on replacing stock 8.8 gears with FR gears that would be even better. thanks in advance
oh and one other thing I mixed up my bearing caps.. I understand that the arrows on caps always point to outside if diff casing... I also see that each cap has a different number on it... is there a way to tell these apart?
