1 - 20 of 78 Posts
how much of a difference will i see w/ 4.56 gears over 4.10s on my 7.5"?
gas mileage is of no concern to me so dont mention that aspect :D
MM's official Chevy guy
ull see a diferance, and even tho u don't care about mpg's just keep in mind if u do a lot of high way driving that u will be seeing higher rpms, and all the efects of that.
higher rpm doesn't necessarily mean engine wear. if he takes care of his motor it would be able ot take the extra 400 rpm all day every day like i said. its only a .4 difference guys and back in the day when gas was cheap as hell even 5.0:1 and higher gears were considered very streetable.
i guess higher rpms would translate to more engine wear, but i plan on upgrading to a 4.2 for the fall(or when i finally have some spending money) anyway :)
true if he takes car and dose proper mantnce a that will be fine, but the other thing i was geting at was we all know who these cars sound pulling higr rmps not so good, i know personaly after 10-15 min. of 3k i would be geting tierd of it and want to slow down.
Not to mention with the torque multiplication a steeper gear gives it can actually help reduce engine wear and increase fuel millage ion certain driving conditions because it takes the engine less work to get to and maintain that rpm. so yes IMO disregard SSS's opinion on not using it as a DD. if he takes care of his engine and Fuel cost is not an issue. then it will be 100% fine as a DD.
Discussion Starter · #18 ·
we are talking a minamal difference over 4.10 here. and like i said back in the 70's steeper gears were considered streetable and used as DD
to bad were not in the 70s!! jk
i really dont care about mpg at all so the extra rpms dont mean anything to me
Im running the stock exhaust still and dont notice ne annoying exhaust note at high rpm. as long as you stick with a chambered setup u should be able to avoid the ricer tone. not compleetly but for the most part.
1 - 20 of 78 Posts
