1 - 5 of 5 Posts
Anyone know the specs that the main and rod journal specs should be on the cobra crank? Im not having any luck on finding anything on bing, or google
Thanks
Travis
Thank ya sir! Now what would be the most tolerance (wear) you would want before having the crank turned?
The crank im looking at has about 53K miles
Im at school so got some info off alldata for you.
Main Bearing Journal Diameter 2.6567269-2.6576718 in
Connecting Rod Journal Diameter 2.085941-2.086728 in
Crankshaft Free End Play 0.005118-0.011850 in
Crankshaft Runout to Rear Face of Block 0.01969 in
Main Bearing Clearance to Crankshaft Desired 0.00098-0.00177 in
Allowable 0.00098-0.00197 in
Bearing Wall Thickness (STD) 0.0965 in
rod bearing clearance should be about the same as the main max of about .002
Awesome thanks man!
1 - 5 of 5 Posts
