1 - 5 of 5 Posts
I need some parts for my pony (specifically, MAF, MAP, TPS and EGR) and was told that the Grand Marquis uses the same motor and parts are interchangable. I also know several other fords that use the 4.6L modular motor (Crown Vic, F-150) and was wondering if those would be compatible.
Is it true that I can use those parts from a Grand Marquis, Crown Vic or F-150?
F150 has some, easiest is going to be finding a Grand Marq, Towncar or Crown Vic 2001 and newer. The three cars have the exact same engines as the mustang
The Towncar! I don't know how I forgot about that one but I knew there was another 4.6 I could use. Okay, so is it also true that I can't use the MAF because of specific programming for each of those vehicles?
I dont see why you couldnt, the tune is the only difference in the hp ratings. In 02 i believe the iat and maf were made to one, just make sure you figure that out from the town car etc and it should be the same maf
Thanks! I'll be sure to do some pre-junkyard researching and hopefuly find some good parts.
1 - 5 of 5 Posts
