1 - 17 of 17 Posts
So I had purchased a 93 GT with a intake backfiring problem and after checking the timing, wiring order, injectors, fuel pressure and rocker nuts, I pulled all the plugs and they all look like normally used plugs but on the #4 valve, it is clean an smells of unburned fuel. Does anybody have any suggestions...I will take any and all at this point, thanks. -Matt-
bad injector? bad plug or wire?
Probably not an injector if it smells like fuel. I second the bad plug or wire, maybe bad cap too.
and if you're reading this again ryan... why?? I'm sure you did the avie for the camaro guys, but what did we ever do to you?!
Attach a timing light on your #4 wire and see if it is firing. The injector could be leaking. Do you notice any fuel smell in the oil or is your oil seem thin?
I changed it just for you, you homophobe
:puke
Nah I prefer to have my face painted.
Discussion Starter · #13 ·
I am a poor bastard.....I can't fix my problem, got spark and oils fine also changed the injectors and still no good.
If it smells of unburned fuel you are looking at an ignition problem I guess. You have confirmed spark at the problem cylinder?
Discussion Starter · #15 ·
i can pull that plug out and put it in the wire and lay it against metal and i get spark, i am so puzzled right now.....working on cars everyday and not being able to figure this out is pissing me off...:mad:
If you pull the #4 plug wire and run the car, does the backfire stop? Maybe you have more than one problem on your hands. From my experience, backfire will only happen if you have a bad intake gasket, or your intake valve is bent, or the intake valve is open at the wrong time (timing), maybe I'm missing a thing or two there, but those are all I've seen.
Discussion Starter · #17 ·
thanks for suggesting that I didn't take notice I will try that and see. Its pouring right now so I will have to check it tomorrow.
1 - 17 of 17 Posts
