1 - 18 of 18 Posts
-206 int. 206 ext @.50 445 lift on both 114 lsa
is this a good cam spec for a 4v?
N/A 4v Guru
its realy mild. It's less than most stage 1 cams. Stage 1 SHM cams are 209/209 452/452
ewwww. lol ok then.. thanks
sorry 330cube the dam 4v section is just so dull and slow
MM's Orangest
For the cost of the SHM Stg 1 (or any of SHM's regrinds) you can buy the entire FR500 kit and the cams are better.
N/A 4v Guru
Yea I was just showing him how bad of a profile those cams where
where can i buy the fr500 cam kit? how much to they usually run? is there a rough like idle?
MM's Orangest
I guarantee that goes for higher than that now ($810). Ford quit making them and were selling them dirt cheap. Now that they're all in the hands of 3rd parties I doubt they will let them go for under a grand. They used to sell for $1600-1700 before the price reduction.
Discussion Starter · #13 ·
im not really in need of some high lift cams right now.. ill probably just get your cams that ur selling mach boy and buy some long tubes.. how much hp does lt's make on 4v engines anyways?
MM's Orangest
Generally 10rwhp for LTs and 10-15rwhp over stock 03-04 numbers on C heads.
Discussion Starter · #15 ·
so are they worth it?
too you?
MM's Orangest
For the cost most definitely if you can do the work yourself.
Discussion Starter · #17 ·
ok.. i found a pair of pacesetters and mid pipe for 400 bucks.. not that bad really eh?
MM's Orangest
Not bad at all.
1 - 18 of 18 Posts
