Baker will scam you on anything you try to buy from him :shiftyeyes
JK
But $175-$200 is usually what bare B-Heads go for on different forums, so I'm guessing you'd get the same for yours. They're probably not B-heads, but B, C, and Navi heads are usually around the same price
There's a reason people always say to just get a 4v motor, cause you need basically everything but the block and rotating assembly from the 4v motor to bolt onto your 2v block.
Heads
Cams
Valves/Springs
Valve Covers
Intake
TB/Plenum
Timing Components
Ignition System (I'm pretty sure it's easier to stick with coil-packs and plugs if that's what the donor heads used, someone can correct me if I'm mistaken)
Exhaust Manifold or Headers
I'm sure I'm forgetting a bunch of stuff...
You might be able to re-use your fuel rails, but I doubt it.
Your stock computer, MAF, and shortblock should work with the new heads but other than that stuff I'm pretty sure you need to get all the 4v stuff.
