1 - 20 of 42 Posts
This is useful stuff, even for the ones who do it all the time. I have print outs of similar charts that I laminate and keep on the side of my roll around tool chest. If you were to add a bolt torque chart, an intake manifold torque sequence chart and an ARP fastener torque chart, you would have a fairly comprehensive engine assembly must have spec article.
5.0L Torque Specs
Belhousing to engine bolts 28-38 ft/lbs
Camshaft sprocket bolt 40-45 ft/lbs
Camshaft thrust plate to engine block bolts 108-144 in/lbs
Crankshaft pulley to vibration damper bolts 35-50 ft/lbs
Cylinder head bolts
-1979-1992
--Step 1 55-65 ft/lbs
--Step 2 65-72 ft/lbs
-1993-up
--Step 1 25-35 ft/lbs
--Step 2 45-55 ft/lbs
--Step 3 75-85 ft/lbs
Differential shaft lock bolt 15-30 ft/lbs
Driveshaft U-joint to pinion flange bolts 70-95 ft/lbs
Exhaust manifold bolts 26-32 ft/lbs
Flywheel mounting bolts 75-85 ft/lbs
Front engine mount nuts 72-98 ft/lbs
Intake manifold to head bolts
--Step 1 96 in/lbs
--Step 2 16ft/lbs
--Step 3 23-25 ft/lbs
Intake manifold (upper intake to lower) 12-18 ft/lbs
Oil filter insert to engine block adapter bolt 20-30 ft/lbs
Oil pan mounting bolts
-1979
--Step 1 (Large bolts) 11-13 ft/lbs
--Step 1 (Short bolts) 7-9 ft/lbs
--Step 2 (Large Bolts) 15-17 ft/lbs
--Step 2 (Short Bolts) 10-12 ft/lbs
-1980 to 1987 9-11 ft/lbs
-1988 to 1993 6-9 ft/lbs
-1994-up 110-144 in/lbs
Oil pickup tube to main bearing cap nut 22-32 ft/lbs
Oil pickup tube to oil pump bolts
-1979 to 1987 10-15 ft/lbs
-1988-up 12-18 ft/lbs
Oil pump mounting bolts 22-32 ft/lbs
Pinion bearing preload 8-14 in/lbs
Pressure plate to flywheel bolts 12-24 ft/lbs
Rocker arm fulcrm bolts 18-25 ft/lbs
Spark plugs 7-14 ft/lbs
Timing chain cover bolts 12-18 ft/lbs
Vibration damper to crackshaft bolt 110-130 ft/lbs
Wheel lug nuts 85-105 ft/lbs
when i start my 5liter it well run fine but when i shut it off and start it up agian it well start droping rpms. It wants to stall and it want go any where i put a 190 holly fuel pump in it and msd cap rotor ignition and wires and it still does it what can it be
ok so im not sure if im posting this in the right section but here it goes anyways, im trying to replace the oil pan gasket in my 1989 5.0, the thing is I need to lift the engine, and the thing with that is ive never lifted an engine before and I would like to do it myself just to get a feel for it, from what i understand there are what like 4 bolts to get it loose ? what else do i have to worry about as far as lifting the engine? transmission connection, wiring etc? please help me out it would be much appreciated thanks guys :)
its not a whole lot its just a bit cramped... you might need to loosen the tranny from the crossmember to allow it to move with the engine thats one bolt there... then you have two to four bolts on the motor mounts i believe its just one on each side... once that is taken care of check all your wiring to make sure none of it is going to get pulled too much you dont want to tear one... then you lift it till you feel the oil pan will come out... it might be like 4 inches around that much
hey can anyone tell me how to tell the difference in a 5.0 roller motor and a non roller motor and what years were they roller and wich were not... thanks...
What would the standard bore and stroke be on a 302?
1 - 20 of 42 Posts
