I have been looking at several different fuel systems and wanted to get some input on the few that I have discovered using google and mustang magazines.
First is Streetfighter 1000 HP Twin Intank Fuel Pump Package. This is a duel pump fuel system, is their any pros or cons having two fuel pumps? I have copied and paste more information below. price for this unit is listed at $1695 plus freight.
600 Litres per hour fuel delivery capable of 1000 hp.
Highest supply in tank fuel system in Australia
NO FUEL SURGE / 1000 hp delivery on near empty fuel tank
Whisper quiet operation
2 x Premium Denso fuel pumps
Huge swirl pot volume supplis cool dense fuel
Manufactured to suit Petrol, E85 (ethanol) and alcohol fuels.
Legal due to direct in tank replacement
Eliminates the need and fumes / noise of external surge tanks.
100% Australian made
Second runner up is the BBR Jackal fuel hat assemble listed at $779 for the 1000HP system and add $150 for the 1400 HP system. This is a single pump drop in system which brings me to ask is there a pro or con having a single fuel pump. I have copied and paste directly from their site information on their fuel system.
BBR is proud to offer our NEW Jackal Fuel System for 2011-12 Mustang GT 5.0L / Boss 302 Customers.
* This is the first direct replacement system to market.
* The only system that uses a 1 pump system ( no more guessing if you have 1 of 3 pump that may have burnt out)
* Re-use your factory level sending unit
* Re-use you factory cross-over tubing
* Detailed Installations Instruction w/ pictures
Our system is capable of supporting over 1400 HP. This is the last fuel system you will ever need to purchase.
Our system is 100% complete; we will include everything you will need. The Jackal system is a direct drop-in billet fuel hat that utilizes your factory cross over tube and factory fuel level sending units. Our system is a return style system system; design to make and support BIG Horsepower.
Last but not least is the return-style fuel system from JPC Racing. They have kits that are capable of making 1100 HP for $1,400 to 2400Hp for $2,000.
Introducing the FIRST drop-in triple pump assembly with the convenience of one outlet feed. Eliminate the need for three lines and fittings and dump the Y-block to save money, drop weight, and reduce the possibility of leaks. Less is more with the JPC/CPE 2011-2013 Mustang GT and BOSS 302 TopHat Fuel Hat.
Horsepower requires fuel and the TopHat is the ultimate solution for any of your big power needs thanks to its ability to hold up to three 400 lph pumps. CPE and JPC Racing designed the TopHat to be a plug and play installation along with reliability and flexibility as it is Gasoline or E85 fuel compatible.
The JPC triple pump return style fuel system is a direct replacement for your stock fuel assembly, while also utilizing the stock level sender placement. With the newly designed cp-e "Top Hat" billet fuel hat keeping the factory angle top for perfect fit and alignment in the 2011-up Mustang fuel tanks. This is a complete system that will support over 850 Horse Power
cp-e "TOP HAT" Features:
MADE IN THE U.S.A.
CNC Machined from high quality billet aluminum
All gas blocked wiring for the Pumps, Ground and Level Sender
Direct plug in harnesses for fuel pumps
Oversize pump retainer for Walbro GSS342 pumps
-8an female feed port and -6an female return ports
Gates 30R10 Submersible Fuel Hose for each pump
System Includes:
cp-e "Top Hat" Triple Pump Walbro Billet Fuel Hat
Magnafuel Pro Star Large EFI Regulator w/ 1:1 Boost Reference
Magnafuel 25 micron Aluminum Inline Fuel Filter
(3) Walbro GSS342 Fuel Pumps
(3) 30amp Relays
All Fragola Black Fittings
High quality Goodyear Black Woven Pushlock Lines
4ga Wire Harness with Relays and Inline Fuse
All required fittings,clamps and fuel pressure guage
NO RAILS INCLUDED, We will provide all the fittings and adaptors to use with stock rails
Are there any other fuel systems out there for these cars and what are some forum member recommendation on these systems?
MADE IN THE U.S.A.
System Includes:
(3) 30amp Relays
